Quote:In general you first translate your reference libraries (e.g. technology library)
Well I downloaded the technology library, in this case TOWER, and "reference" this "new library" on my cds.lib, until here everything is ok.
Quote:May I ask if there is any essential reason why you have to translate you database?
The essential reason is, now I'm starting one brand new project and for this one it's not the main issue but the previous one is.
I want to be able to understand this "translator" to be able to "move" the previous CDB project to this Open Access, why?!? I don't know if the designers will want to re-use some of the block's in this new one, and instead of spending time re-doing everything again I will spend some time now understanding and be able to do this translation.
Quote:By the way a stream in mapping table is used for reading in GDSII databases and has nothing to do with translating database form CDBA to OA
Probably you are right, the thing is like I said to you I made some "google" regarding this issue and one of the bit's was related to a Strm table and I tried to use it, but like I said it's the same.
Thanks for your time trying to help me "debugging" this issue.
Best Regards
