Jul 21st, 2024, 5:23pm
AC simulation of common-mode feedback in loop... (Read 608 times)
thomasross20
Oct 06th, 2008, 4:21am
I've currently got a telescopic amplifier with a differential-difference amplifier for the commno-mode feedback (basically an amp which compares the average of the outputs to a common mode level).
I am having trouble plotting the a.c. response of the common-mode part of the circuit. I want to see the gain and phase from the outputs of the amp to the input off the DDA which feed back to the amp and then to the output.... the system is unstable and I cannot simulate the a.c. to see the poles & zeros.
I have tried placing a large RC low-pass from the outputs of the amp to the input of the DDA, but no luck.
Thanks for any help,
Thomas
thomasross20
Re: AC simulation of common-mode feedback in loop...
Reply #1 - Oct 6th, 2008, 8:00am
I think I have solved my problem; thanks for those that took the time to read, anyway Smiley
Frank Wiedmann
Munich, Germany
Reply #2 - Oct 6th, 2008, 8:40am
You might want to search this forum for "stb analysis".
