baohulu
china
hi, all I have a question to ask you. in CT sigma-delta modulator, excess loop delay is from to sources: one is DAC input delay, the other is DAC clock to Q delay in DAC itself. in most books, there is a diagram which has two rectangles and the x-axis is time, one is rising at "0" point (the original), the other at a delayed time, "td", and then the books give method to compensate the delay time "td". I want to ask what is the y-axis, is it a DAC input or a DAC output? if it is a DAC output, then it means, both DAC input delay and DAC clock to Q delay can be compensated; if it is just the input of the DAC, then does it mean only DAC input delay (which is caused by quantizater ) can be compensated? in the book " Continuous time Delta-Sigma AD conversion" written by M.Ortmanns & F. Gerfers, it doesn't tell the difference of the two delay reasons, and it seems the compensation methods can compensate both the two delay, right?
