Apr 25th, 2025, 11:13pm
differential pair offset (Read 3972 times)
PalmRunner
Oct 14th, 2008, 1:54am
Hello all,
I am writing my first post in this useful forum starting with a question. Here is the background:
I need to design a simple continuous time comparator, so I started with the basic two stage comparator described in the Allen/Holberg book. I use Spectre Monte Carlo analysis to simulate the offset. Here are the 1 sigma results with different aspect ratio of the input pair, but same area:
W/L           1 sigma
4/5      ->  1.59mV
10/2    ->  1.39mV
20/1    ->  1.35mV
40/0.5 ->  1.34mV
My intuition tells me that longer transistors or those biased in a strong inversion should exhibit less random / delta Vt mismatch, as it is in a current mirror for example. The question is why I get just the opposite effect here?
Any input is greatly appreciated.
Thanks!
I know enough to know I don't know enough.
raja.cedt
Re: differential pair offset
Reply #1 - Oct 14th, 2008, 3:23am
I don't know the answer for your question but one conceptual correction to your discussion is variations is ∝1/√(w*L). so according to this pilgrims model offset for your all samples should same.but i don't know how they came like that
PalmRunner
Reply #2 - Oct 14th, 2008, 4:44am
In my understanding, the operating point should also influence the spread, not only the transistor area. For example, larger Vgs overdrive basically has a positive effect on the Ids spread, while it seems to be the opposite for a differential pair.
aaron_do
Reply #3 - Oct 14th, 2008, 5:47am
If i remember correctly, there is nothing wrong with your simulation. According to the analysis in Razavi's analog IC design book, offset actually increases with overdrive for a differential pair.
cheers,
Aaron
PalmRunner
Reply #4 - Oct 14th, 2008, 10:13am
Thanks Aaron, I found the chapter in Razavi’s book. I follow the equations, but honestly I am still having hard times to grasp what is behind. Why lowering the Vgs-Vt would help us to reduce the offset. In my understanding low overdrive voltage would make the input pair more sensitive to Vt variations, which in turn would reflect in larger current variations. Obviously I am missing something very basic. Can someone help me with somewhat more intuitive explanation?
HdrChopper
Reply #5 - Oct 14th, 2008, 11:28am
Hi
One possible explanantion could be related to the offset contribution from your active load. The larger the input pair gm, the less contribution from the load to the total input diff pair. This is what you are getting out of your simulation.
Hope this helps
Tosei
Keep it simple
