Sep 3rd, 2024, 2:17pm
The capacitive load of transmission (Read 3093 times)
dandelion
Oct 16th, 2008, 2:51am
Hi
I am designing a block whcih will drive a transimission (50cm long) and a FPGA chip.The block will works in 1.25G.
I wonder, in simulation, how to define the load? especially the capacitive load? 5pF is enough?
BTW, the output of the block is PECL.
Re: The capacitive load of transmission
Reply #1 - Feb 15th, 2009, 1:01pm
You need to define the PCB trace and width, min/max criteria. With that in hand you can then get from a number of sources (Google PCB dielectric capacitance) the capacitance limitations for the traces. If you are doing high frequency design (above 10MHz for the sake of discussion) you may want to do a more complete PCB trace model that includes distributed trace RLC elements and transmission line models.
