Oct 28th, 2024, 3:59pm
track and hold circuit parameter (Read 4068 times)
nuoan
Oct 16th, 2008, 5:27pm
A simple track and hold circuit could be found in the literature. The schematic is shown below
I would like to do some simulation for this circuit on Cadence. My input data are:
1. Vin+ = 1.2V, Vclk =20GHz,
2. the frequecy of Vin+ is Fin=5GHz
My problems are:
1) how to determine the Vclkb?
2) how to obtain a common-mode input voltage?
3) if I want to increase the input bandwidth, what can I do?
4) Do anyone have a detailed parameter for this circuit?
I want to get some inputs for how to solve these problems.
Thanks in advance
nuoan
raja.cedt
Re: track and hold circuit parameter
Reply #1 - Oct 17th, 2008, 4:47am
for what purpose u r using this  S/H circuit?Becaz S/H circuits selection based on application.I  am getting why you shorted mosfets whose gate is connected to clkb.Better use some gate boosted kind of circuit.use the following reference.its linearity is excellent.
  A 1.5-V, 10-bit, 14.3-MS/s CMOS pipeline analog-to-digital converter A. Abo and P. Gray, IEEE Journal of Solid-State Circuits, May 1999
nuoan
Reply #2 - Oct 20th, 2008, 3:54pm
raja.cedt wrote on Oct 17th, 2008, 4:47am:
Thanks!  raja
This Track and Hold circuit is used for the front end of high speed flash ADC, say 5Ghz.
By  using 5GHZ as sampling frequecy, when the input frequency is 2.5GHz, the simulation shows that the output signal is distorted very seriously.
I want to improve the bandwidth. Can someone give some suggestion and direction?
To increase the input bandwidth, which parameter can I change?
or can I add some circuit? Is there some good reference available?
raja.cedt
Reply #3 - Oct 21st, 2008, 1:41am
hi,
   for flash use simple switch followed by common drain amp(buffer).its more than enough for getting higher bandwidth(i think this ckt will give pretty nice BW than others.).but here you will have to loose one VGs droop across the buff  so as to compensate for that use another buffer with opposite polarity.
V. Srinivas, S. Pavan, A. Lachhwani and N. Sasidhar," A Distortion Compensating Flash Analog to Digital Conversion Technique,"  IEEE Journal of Solid State Circuits.  September 2006
nuoan
Reply #4 - Oct 22nd, 2008, 3:27pm
raja.cedt wrote on Oct 21st, 2008, 1:41am:
hi,
thanks, is there any technique to obtain wideband?
raja.cedt
Reply #5 - Oct 22nd, 2008, 9:43pm
why you want wide band? don't think if u can find some fast S/H ckt that will help.Because inside the flash  comparator array is very difficult to make that much fast.Generally S/H is double bandwidth when compared to Falsh core (if you want one sampling ahead the comparison).
Any how if you are eager to get wide band S/H use  super sourse follower circuit (this circuit you can get in razaavi current mirrors chapter)in S/H.
Can you plese tell me the toplevel specs means
1.No of bits
2.Targeting ENOB
3.how much sampling rate
4.application (audio/video/sensor)
5.FOM
so that i can tell you clearly
