Paul
Hi Neo,
Conducting material is usually platinum or tungsten, the latter being 2x less resistive, though still 3x more than Cu. Notice the deposition for longer stripes is done in several steps, which again increases resistivity.
I am a designer, not a FIB guy, but I would guess that at best you might get some samples operating at the desired speed, but the FIB yield at these frequencies might not be tremendous. At least, talk to your FIB guys before proceeding, they should know better what you can expect based on the actual case (how deep do they have to mill before getting to the desired wire, how large is the wire to contact, etc...).
This might not be critical to you, but FIB usually also comes with some leakage in the milling region.
Regards Paul
