Jul 21st, 2024, 1:29pm
RFDE momentum error (Read 3887 times)
ReadWDX
China
RFDE momentum error
Oct 18th, 2008, 7:46pm
Hi,all
  I have designed a 5GHz VCO,I want to do EM simulation in RFDE momentum,but when I did this simulation,RFDE gave me this error:
" Mesher input does not contain any valid shapes .Your shapes might have been ignored because they were drawn as polylines on  the strip or slot layer they were on an unmapped layer."
how can I do to correct this error? I indeed need  help, thanks !
ReadWDX
China
Re: RFDE momentum error
Reply #1 - Oct 21st, 2008, 5:36am
When I define substrate file, I  give wrong information of layers, so momentum can not find the shapes in the substrate file I haved defined.
but I now face another difficulty,which is that when I do momentum simulation, this warning is given: " could not create the dataset since no citi file could be found", if someone has faced it ,and he/she can give me a little of advice, I will be very grateful.
