aaron_do wrote on Jan 13th, 2009, 1:02am:I just realized how vague the question was...
Still very vague.
aaron_do wrote on Jan 13th, 2009, 1:02am:I want to be able to see the Logarithmic amplification of the BJT for several different input frequencies. So i guess i need RMS output current versus input voltage.
You can do by using PSS analysis where fudamental frequency of PSS is swept.
But you can not do this tasks from GUI.
In GUI of Cadence Spectre PSS, you can't use variable as fundamental frequency.
So you have to run Spectre by using netlist or OCEAN Script.
In Agilent Simulators such as ADSsim or GoldenGate, you can use variable as fundamental frequency even in GUI.
So you can sweep fundamental frequency easily from GUI in Agilent Simulators.
aaron_do wrote on Jan 13th, 2009, 1:02am:I was thinking of running PSS analysis, but PSS splits the signal into harmonics.
You can evaluate RMS value easily by using "pss_fd" data.
Evaluation of RMS value from harmonics is very common in HB analysis.
What do you confuse ?
