Oct 28th, 2024, 3:53pm
leakage in 0.13u process (Read 1654 times)
hugh
Oct 30th, 2008, 8:07pm
I'm designing a PLL and using the tsmc 0.13G process. But the gate leakage current is about 1nA/um^2 for NMOS. So when using nmos as capacitors what should I do?
Another question is the Ioff is also high, 500pA for NMOS of 10/0.13. So the power down current for a large scale digital circuit is also very high, I guess about 100uA for about 200K gates. How to solve this?
Some suggest to use the 0.13 LP process. However I heard the leakage current is more severe in 90nm, and since we will migrate to 90nm later, I think we'd better solve it now.
Thanks for any suggestions,
Hugh
Monkeybad
Re: leakage in 0.13u process
Reply #1 - Nov 3rd, 2008, 12:45am
Hi! hugh
You can use the 3.3V NMOS rather than the 1.2V for the low pass filter capacitances. The leakage current of 3.3V NMOS is much smaller than the 1.2V.
hugh
Reply #2 - Nov 3rd, 2008, 2:30am
Thanks, Monkeybad.
But the cap density of 3.3V device is about 3 times lower, the area cost will be high.  Is there any circuit techniques possible?
B.R.,
Hugh
Monkeybad
Reply #3 - Nov 3rd, 2008, 7:14pm
Some papers discuss using another charge pump to compensate the leakage current. Here is one of these papers I've found before. But it uses 90nm process.
"A 1-4 Gbps quad transceiver cell using PLL with gate-current leakage compensator in 90nm CMOS"
In my design I use the 3.3V device to solve this problem. The area cost is acceptable for my application now.
Berti
Reply #4 - Nov 4th, 2008, 3:49am
I think that the gate leakage of 1nA/um2 is for vgs=1.2V. If your voltage at the gate is lower leakage will reduce, too. Maybe then it is ok for you design.
Otherwise you could also think about MIM/metal caps...
hugh
Reply #5 - Nov 5th, 2008, 3:56am
Thanks, Monkeybad & Berti.
Now I think the gate leakage can be handled by careful design.
What about the off state current? Our SoC has about 2M gates. And the power down current is now about 500uA, unacceptable. I think the only way is to power down the LDO for digital circuits also. But this need the support of system vendor.  :(
Any suggestions?
B.R.
Hugh
Berti
Reply #6 - Nov 5th, 2008, 10:15pm
If no high-Vt devices are available you could power the digital core at a lower
supply voltage....if you timing constraints allow for that.
You will need level-shifter for the outputs, but the leakage will reduced a lot.
Cheers
hugh
Reply #7 - Nov 6th, 2008, 3:20am
Berti wrote on Nov 5th, 2008, 10:15pm:
Cheers
Really good idea. Also some paper point to this way.
Many thanks.
Tlaloc
Dallas, TX
Reply #8 - Nov 6th, 2008, 8:14am
I have also heard of a very large switch being put in series with the supply to power down portions of logic that are not being used.  Of course, it would still leak if you are using the same type of device, but since it would be a PMOS, you should come out ahead.  Using a higher Vt device--with the larger area--would also reduce the leakage.
