Sep 24th, 2026, 11:56am
Hierarchically referece a node in verilog-A instantiation (Read 953 times)
ssdfz
Nov 04th, 2008, 8:35pm
Hi all:
I have a question regarding getting access to hierarchical node in VA and hope it can be answered by experts in this forum. For example, I need to get access to two nodes called global.vdd and global.vss. In Verilog-HDL, I simply create a module called global and their net can be hierarchically referred. I tried the similar thing in verilog-A, but it seems to fail.
One example would be that if I need to instantiate the following VA model
     module test(A, Z);
           input A;
           output Z;
           electrical A;
           electrical Z;
           electrical B;
           test1 i0 (.A(B), .Z(B));
           test2 i1 (.A(B),.B(global.vss), .Z(Z));
I tried to write a separate global.va model which is having vss, and include the file in my hspice input file, but no luck.
Your opinion will be highly appreciated!
jbdavid
Re: Hierarchically referece a node in verilog-A instantiation
Reply #1 - Nov 4th, 2008, 9:44pm
that is not something that ALL the Verilog-A simulators support.
What happens in many simulators with the Spice (or spectre) netlist on top is that you need to put those ports Explicitly in the model, and then connect them to global nets in the spice netlist.
jbd
jbdavid
