Ziolizzi
Hi everybody,
this is my first message, I'm a new member.
Let me explain my problem with the Pnoise analysis. I tried to simulate a very simple S/H circuit in order to plot the KT/C noise at the output node. In the following you can see the netlist file I used:
simulator lang=spectre global 0 parameters VDD=1.8 include "/cds/technologies/umc_018_2008/designkit/UMC_18_CMOS/../Models/Spectre/MM180_SP ECTRE_MAIN_V142.lib.scs" section=tt include "/cds/technologies/umc_018_2008/designkit/UMC_18_CMOS/../Models/Spectre/MM180_SP ECTRE_MAIN_V142.lib.scs" section=diode include "/cds/technologies/umc_018_2008/designkit/UMC_18_CMOS/../Models/Spectre/MM180_SP ECTRE_MAIN_V142.lib.scs" section=bjt include "/cds/technologies/umc_018_2008/designkit/UMC_18_CMOS/../Models/Spectre/MM180_SP ECTRE_MAIN_V142.lib.scs" section=res_typ include "/cds/technologies/umc_018_2008/designkit/UMC_18_CMOS/../Models/Spectre/MM180_SP ECTRE_MAIN_V142.lib.scs" section=mimcaps_typ include "/cds/technologies/umc_018_2008/designkit/UMC_18_CMOS/../Models/Spectre/MM180_SP ECTRE_MAIN_V153.lib.scs" section=tt include "/cds/technologies/umc_018_2008/designkit/UMC_18_CMOS/../Models/Spectre/018-rf-v 2d4-control.scs" include "/cds/technologies/umc_018_2008/designkit/UMC_18_CMOS/../Models/Spectre/MM180_RE S_V111.lib.scs" section=res_typ
// Library name: prova // Cell name: prova_noise_RF // View name: schematic V2 (net7 VCM) vsource dc=0 type=dc pacmag=1 I10 (SOUT 0 OUT 0) SH_IDEAL M0 (net7 P2 OUT _net0) p_18_mm w=10u l=180.0n ad=4.9e-12 as=4.9e-12 \ pd=20.98u ps=20.98u m=(1)*(1) M24 (net7 P1 OUT 0) n_18_mm w=10u l=180.0n ad=4.9e-12 as=4.9e-12 pd=20.98u \ ps=20.98u m=(1)*(1) C0 (OUT VCM) capacitor c=10p ic=0 V0 (VCM 0) vsource dc=VDD/2 type=dc V3 (_net0 0) vsource dc=VDD type=dc V5 (P2 0) vsource type=pulse val0=VDD val1=0 period=2.5u delay=0 rise=1n \ fall=1n width=1u V7 (P1 0) vsource type=pulse val0=0 val1=VDD period=2.5u delay=0 rise=1n \ fall=1n width=1u simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \ tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \ digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \ sensfile="../psf/sens.output" checklimitdest=psf pss pss fund=400K harms=0 errpreset=conservative tstab=16.6u + saveinit=yes tstabmethod=gear2only maxacfreq=6M pnoise ( OUT 0 ) pnoise start=0.001 stop=4M dec=200 + maxsideband=5 iprobe=V2 refsideband=0 annotate=status + saveallsidebands=yes modelParameter info what=models where=rawfile element info what=inst where=rawfile outputParameter info what=output where=rawfile designParamVals info what=parameters where=rawfile primitives info what=primitives where=rawfile subckts info what=subckts where=rawfile saveOptions options save=allpub ahdl_include "/home/pasquale/cad18_v2/prova/SH_IDEAL/veriloga/veriloga.va"
As you can see the circuit is very simple, furthermore I downloaded the SH_IDEAL verilogA model directly from this site.
The simulation settings are the same of the file "Simulating Switched-Capacitor Filters with SpectreRF" (Listing1). At the end of the simulations, if I try to plot the output PDS the result is very different from Figure4 (in the same document). I really don't understand where the problem is..
Do you have any suggestion?
Thank you for your support.
Ziolizzi
