Aug 15th, 2024, 9:14am
KT/C noise with Pnoise analysis (Read 2148 times)
Ziolizzi
Nov 07th, 2008, 6:35am
Hi everybody,
this is my first message, I'm a new member.
Let me explain my problem with the Pnoise analysis.
I tried to simulate a very simple S/H circuit in order to plot the KT/C noise at the output node. In the following you can see the netlist file I used:
simulator lang=spectre
global 0
parameters VDD=1.8
include "/cds/technologies/umc_018_2008/designkit/UMC_18_CMOS/../Models/Spectre/MM180_SP
ECTRE_MAIN_V142.lib.scs" section=tt
ECTRE_MAIN_V142.lib.scs" section=diode
ECTRE_MAIN_V142.lib.scs" section=bjt
ECTRE_MAIN_V142.lib.scs" section=res_typ
ECTRE_MAIN_V142.lib.scs" section=mimcaps_typ
ECTRE_MAIN_V153.lib.scs" section=tt
include "/cds/technologies/umc_018_2008/designkit/UMC_18_CMOS/../Models/Spectre/018-rf-v
2d4-control.scs"
include "/cds/technologies/umc_018_2008/designkit/UMC_18_CMOS/../Models/Spectre/MM180_RE
S_V111.lib.scs" section=res_typ
// Library name: prova
// Cell name: prova_noise_RF
// View name: schematic
V2 (net7 VCM) vsource dc=0 type=dc pacmag=1
I10 (SOUT 0 OUT 0) SH_IDEAL
M0 (net7 P2 OUT _net0) p_18_mm w=10u l=180.0n ad=4.9e-12 as=4.9e-12 \
       pd=20.98u ps=20.98u m=(1)*(1)
M24 (net7 P1 OUT 0) n_18_mm w=10u l=180.0n ad=4.9e-12 as=4.9e-12 pd=20.98u \
       ps=20.98u m=(1)*(1)
C0 (OUT VCM) capacitor c=10p ic=0
V0 (VCM 0) vsource dc=VDD/2 type=dc
V3 (_net0 0) vsource dc=VDD type=dc
V5 (P2 0) vsource type=pulse val0=VDD val1=0 period=2.5u delay=0 rise=1n \
       fall=1n width=1u
V7 (P1 0) vsource type=pulse val0=0 val1=VDD period=2.5u delay=0 rise=1n \
       fall=1n width=1u
   digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
   sensfile="../psf/sens.output" checklimitdest=psf
pss  pss  fund=400K  harms=0  errpreset=conservative  tstab=16.6u
+    saveinit=yes  tstabmethod=gear2only  maxacfreq=6M
pnoise  (  OUT  0  )  pnoise  start=0.001  stop=4M  dec=200
+       maxsideband=5  iprobe=V2  refsideband=0  annotate=status
+       saveallsidebands=yes
ahdl_include "/home/pasquale/cad18_v2/prova/SH_IDEAL/veriloga/veriloga.va"
As you can see the circuit is very simple, furthermore I downloaded the SH_IDEAL verilogA model directly from this site.
The simulation settings are the same of the file "Simulating Switched-Capacitor Filters with SpectreRF" (Listing1).
At the end of the simulations, if I try to plot the output PDS the result is very different from Figure4 (in the same document).
I really don't understand where the problem is..
Do you have any suggestion?
Thank you for your support.
Ziolizzi
Re: KT/C noise with Pnoise analysis
Reply #1 - Jan 3rd, 2009, 3:15pm
Isn't it just because you have a higher clock frequency, and the results plotted on a log x-axis (the paper has them on a linear x-axis).
