Aug 19th, 2024, 12:22pm
nA current reference (Read 227 times)
manodipan
Nov 25th, 2008, 2:04am
Hi guys,
can u guys suggest some very good current reference of around 10 nA with very little sensitivity to process,temperature etc...thanks
raja.cedt
Re: nA current reference
Reply #1 - Nov 25th, 2008, 2:42am
hi manodeepan,
                         i have some questions regarding u r questions.1.For what application u need this 2.in which technology.why i am asking is i am working in 65nm, in this technology even 5*1 mos transistor have around 6nA gate current.so may be u can get 10nA reference in older technologies,but here it is very difficult(for getting presise reference u need to use -ve feed back,so inherently u have to mos). so ples etell me the which tech nod eu r working so that we can think about circuit.
Thank you
HdrChopper
Reply #2 - Nov 25th, 2008, 6:38pm
Check this reference
"CMOS Current Reference Without Resistance"
Henri J. Oguey and Daniel Aebischer
IEEE JOURNAL OF SOLID-STATE CIRCUITS, VOL. 32, NO. 7, JULY 1997
Tosei
Keep it simple
manodipan
Reply #3 - Nov 27th, 2008, 1:14am
Hi Raja,
The technology is 130 nm and current linearity is also an important factor...
raja.cedt
Reply #4 - Nov 27th, 2008, 2:22am
hi manodeepan,
                         what do u mean by linearity.i guess its a current reference.do you want controlled current reference?
Thank you.
manodipan
Reply #5 - Dec 2nd, 2008, 2:14am
Hi raja,
You are right it's a current reference with very less process and temperature sensitivity and good o/p resistance throughout the o/p range..
rf-design
Reiner Franke
Reply #6 - Dec 15th, 2008, 1:51pm
Regarding gate leakage you can use possible thick-oxide devices used for output driver stages. The gate and the channel leakage is much lower.
For the nA-current source I suggest to start with a higher current level. So for instance using a bandgap and driving a low tempco resistor with current to equal the bandgap voltage.
Then use a current divider which is made of a mirror MOS pair where the low current source is shifted by a voltage equal to
log(a)*m*Vt
m: subthreshold factor, Vt: temperatur voltage, a: current division factor
This exponential current multiplier voltage should be derived from the k*T-Cell made of MOS instead of parasitic PNP's
The you can get very low current in some % accuracy range
