Oct 28th, 2024, 3:53pm
method to decrease Vth of pMOS? (Read 6393 times)
trashbox
Nov 25th, 2008, 4:15am
I'm design a large output current linear LDO with pMOS as pass element and want to save area by using small W/L pMOS.
Is there any method to decrease pMOS Vth? Thanks!
Trashbox
ACWWong
Oxford, UK
Re: method to decrease Vth of pMOS?
Reply #1 - Nov 25th, 2008, 6:58am
you could bias the back gate at ground...
HdrChopper
Reply #2 - Nov 25th, 2008, 6:44pm
You could try biasing the body of the pass transitor about 200mv below the supply voltage.
What is the min drop out you need for you app? Depending on the drop out the pass transistor migth not need to be super large. You could eventually allow the pass transistor to enter into triode region without major consequences since usually the pass transistor stage does not gain too much, even when working in sat region (since usually the load is very small to achieve large gains).
Hope this helps
Tosei
Keep it simple
trashbox
Reply #3 - Nov 26th, 2008, 2:00am
Hi ACWWong!
You idea inspires me! But it really dangerous. Haha..
Hi Tosei!
Thanks very much for your replying my questions always.I will try it. Smiley
William
raja.cedt
Reply #4 - Nov 26th, 2008, 9:46pm
hi tosei,
           i have a question regarding u r ans. from gain point of view it doesn't matter whether pass transistor is working in sat or triode(as you said,provided ldo is heavyly loaded),but from supply noise point of view if it is triode it will pass most of the noise to output. correct me if i  ma wrong.
hi trashbox,
                   the following paper might help you,they have  implemented same idea(more or less using body terminal,but its prone to forward biasing)
36 IEEE JOURNAL OF SOLID-STATE CIRCUITS, VOL. 33, NO. 1, JANUARY 1998
A Low-Voltage, Low Quiescent Current,Low Drop-Out Regulator
Gabriel A. Rincon-Mora, Member, IEEE, and Phillip E. Allen, Fellow, IEEE
HdrChopper
Reply #5 - Nov 27th, 2008, 3:52am
Hi raja,
That is correct and a very well known trade off: minimum drop out voltage vs PSRR. If the pass transistor goes into triode region then PSRR is degraded.
My answer just pointed to optimize the minimum operation supply voltage withouth considering PSRR issues.
Tosei
Keep it simple
raja.cedt
Reply #6 - Nov 27th, 2008, 9:14pm
hi tosie,
           thanks for your answer.can please tell me is there any advantage of pass transistor in triode apart from low drop(may be i guess stability may improve).can you give any reference based on this?
Thank you.
Reply #7 - Dec 5th, 2008, 1:48pm
In a semi serious suggestion:
Change the threshold implant doping density in the channel, under the gate. It is generally the ion implant stage after after photo resist for the transistor body and prior to the gate polysilicon. Higher temperature or longer implant time period should result in a lower threshold voltage.
Cheesy
Now the big question - Can you control the foundry?  ;D
-- Jerry
PalmRunner
Reply #8 - Dec 5th, 2008, 2:55pm
Possible way to decrease the threshold voltage is to connect the bulk to the gate. This is so the called DTMOS device (Dynamic Threshold MOS). You have to be careful with the operating point of such device, because the bulk is slightly forward biased.
PalmRunner
I know enough to know I don't know enough.
SATurn
Reply #9 - Dec 10th, 2008, 2:06pm
Well, the must effective way is to bias the bulk of the transistors. In a PMOS device, by reducing the bulk voltage you can reduce the device VTH. Ofcourse you need to make sure that the SB junction will not be forwarded. The other possibility is increasing the length of transistor that can help to reduce the VTH a little bit (revese short channel effect).
SATurn
