Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 19
th
, 2024, 6:17pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› Loop bandwidth
Previous topic
Next topic
Loop bandwidth (Read 1954 times)
raja.cedt
Loop bandwidth
Dec 09
th
, 2008, 10:14pm
hi,
i have one question regarding loop bandwidth.i am designing a PLL whose fref=600Mhz.so i selected loop bandwidth 60MHZ for stability reasons.there are op amps in charge pump.so how to select op amp UGB's?
Thank you.
IP Logged
SATurn
Re: Loop bandwidth
Reply #1 -
Dec 10
th
, 2008, 2:02pm
If this amplifier in the charge pump affects the loop transfer characteristics, then its bandwidth should be selected high enough to make sure that the phase margin of the PLL does not degrade.
SATurn
IP Logged
raja.cedt
Re: Loop bandwidth
Reply #2 -
Dec 11
th
, 2008, 12:30am
hi,
Thanks for your reply.i took 10 times than loop bandwidth.is it ok.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
