Analog_Rex wrote on Dec 13th, 2008, 12:45am:Hi...
I have a basic circuit with an opamp using a simple negative feedback configuration with two resistors. When i tested the circuit, I noticed that for a 1V input it saturates on the positive output. I would want to improve this basic opamp circuit in a way that it does not saturate even when the input is 1mV.
Can somebody help me with this?
Thank you
Rex
It would be very helpful if you could give us the gain of your opamp stage.
