vabian
Sorry, but my English is not good. I have a problem with a adder. Hery is a code and a result of simulation (in cver):
module sumator_bez(a,b,wykonaj,wynik); input [3:0] a,b; input wykonaj;
output [3:0] wynik; reg [3:0] wynik;
always @(wykonaj) begin if(a[3:0] > b[3:0]) begin wynik = a - b end else begin wynik = b - a; end end
initial begin #130 $finish; end
module test; reg [3:0] a,b; reg wykonaj; wire [3:0] wynik; sumator_bez S (a,b,wykonaj,wynik);
initial begin a = 10; b = 5; wykonaj = 1; #50 a = 7; b = 5; wykonaj = 1; #50 a = 3; b = 4; wykonaj = 1; end
initial begin $monitor($time, ": %d - %d = %d",a,b,wynik); end endmodule
Simulation: Highest level modules: test
0: 10 - 5 = 5 50: 7 - 5 = 5 100: 3 - 4 = 5 Halted at location **mod.v(27) time 130 from call to $finish. There were 0 error(s), 0 warning(s), and 4 inform(s).
Why did the result of a-b don't change?
When I change instuction wynik=a-b on assign wynik=a-b I get a new result of simulation. But if-else don't work properly. Why? Highest level modules: test
0: 10 - 5 = 5 50: 7 - 5 = 2 100: 3 - 4 = 15
Thanks for any help!!!
