Jul 17th, 2024, 6:40pm
Simple adder - help!! (Read 2800 times)
vabian
Nov 27th, 2008, 10:06am
Sorry, but my English is not good.
I have a problem with a adder. Hery is a code and a result of simulation (in cver):
module sumator_bez(a,b,wykonaj,wynik);
input [3:0] a,b;
input wykonaj;
output [3:0] wynik;
reg [3:0] wynik;
always @(wykonaj) begin
   if(a[3:0] > b[3:0])
   begin
       wynik = a - b
   else
   begin
       wynik = b - a;
initial begin
   #130 $finish;
module test;
reg [3:0] a,b;
reg wykonaj;
wire [3:0] wynik;
   sumator_bez S (a,b,wykonaj,wynik);
initial begin
       a = 10; b = 5; wykonaj = 1;
   #50 a = 7; b = 5; wykonaj = 1;
   #50 a = 3; b = 4; wykonaj = 1;
initial begin
   $monitor($time, ": %d - %d = %d",a,b,wynik);
Simulation:
Highest level modules:
test
0: 10 - 5 = 5
50: 7 - 5 = 5
100: 3 - 4 = 5
Halted at location **mod.v(27) time 130 from call to $finish.
There were 0 error(s), 0 warning(s), and 4 inform(s).
Why did the result of a-b don't change?
When I change instuction wynik=a-b on assign wynik=a-b I get a new result of simulation. But if-else don't work properly. Why?
test
0: 10 - 5 = 5
50: 7 - 5 = 2
100: 3 - 4 = 15
Thanks for any help!!!
Re: Simple adder - help!!
Reply #1 - Nov 27th, 2008, 10:55am
You only recompute the output upon changes in wykonaj, but that signal never changes.
vabian
Reply #2 - Nov 27th, 2008, 12:24pm
Ken Kundert wrote on Nov 27th, 2008, 10:55am:
Could you tell me, what I should to change in my code? I will weveryy great full
Reply #3 - Nov 27th, 2008, 10:46pm
Use "always @(*) begin" rather than "always @(wykonaj) begin".
