I assume you don't really want a histogram of the standard deviation, but instead a histogram of the period variation?
In IC613, there's the "histo" calculator function. So you can calculate the freq (versus cycle, say), and then invert it, and then use the histo function (you specify the number of bins, and min and max values, and the result is a histogram as you want).
Can you use IC613? You could just run "viva" standalone and look at your existing simulation results.
