Aug 19th, 2024, 10:19am
CMFB for pseudo differential amplifier (Read 578 times)
yixiusky
Dec 02nd, 2008, 9:17pm
I would like to ask one question:
when we design pseudo differential amplifier, the common mode feedback circuit also should pseudo differential (without tail current source) or not ?
thank you very much
View Profile yixiusky   IP Logged
Re: CMFB for pseudo differential amplifier
Reply #1 - Dec 5th, 2008, 1:13pm
Could you please better define the question? Differential architectures I think we all understand, Complimentary architectures most of us understand. but what is "pseudo differential?"
thanks - Jerry
rf-design
Reiner Franke
Reply #2 - Dec 15th, 2008, 1:59pm
Pseudo-differential means two single-ended stages used with complementary signals. Typical no common-mode rejection but if the signals are used as differential cancelation of some negative effects could occur.
No commom mode control needed. If the single-ended stages make a level shift between in and out and you can control that this will be a common mode control.
