Jul 20th, 2024, 1:19pm
Low to High Voltage Level Shifter (Read 2691 times)
wave
Dec 04th, 2008, 1:57pm
Hello - Can anyone suggest good architectures (papers?) of Logic Level shifters.
I need a low voltage (say 1V) shifted to a higher voltage (variable, 3-10V) range.  I have various oxide devices and Vt flavors.
One complicating issue is, the lower supply may fall away and the output should remain in state.  ie, latched.
Once we have a latching mechanism, a 2nd issues is the condition on startup.  It needs a skew or POR, perhaps.
Finally, I cannot tolerate DC current in either high or low state.
One idea is a cross coupled NOR gate, like an R/S latch.
thanks for your comments.
~WAVE     Tongue
rf-design
Reiner Franke
Re: Low to High Voltage Level Shifter
Reply #1 - Dec 15th, 2008, 2:59pm
The crosscoupled PMOS with NMOS driven from 1V-logic works only if the gate could withstand 10V. That is rare to my knowledge.
If the the high voltage logic is e.g. between 10V and 7.5V made of thick-oxide with isolated NMOS then the latch must be current controlled from the 1V-0V-logic.
The latch could have a normal asynchron reset.
Is the voltage like above? What process you use?
wave
Reply #2 - Dec 15th, 2008, 3:18pm
rf-design wrote on Dec 15th, 2008, 2:59pm:
In this case, I do actually have 10V xters to run the latch off of.
However, this is also a general problem with multiple supplies.
I know some guys have to level shift 1.8 to 3V, using dual gate Oxide transistor.   Or 1V to 2.5V, etc.
regards,
Wave
