Aug 15th, 2024, 10:23am
PLL design (Read 1985 times)
raja.cedt
PLL design
Dec 09th, 2008, 10:50pm
hi,
   i am designing a PLL,in that how to select loop filter elementc1 which is in series with zero providing resistor.some where i read it depends on the charge pump leakage current and mismatch between up and down current sources. but i didn't understood much.If any body have any  design example  documents that would be great help to me .
Thank you.
DaveB
Re: PLL design
Reply #1 - Jan 4th, 2009, 6:44pm
A pretty good, free reference on PLL design is from National Semiconductor, Here is the link
http://www.national.com/analog/timing/pll_designbook
Read through that, and you'll have a much better understanding of Loop filter design
Dave
