Aug 15th, 2024, 12:18pm
Minimum cap (Read 2338 times)
Tareeq
Minimum cap
Dec 19th, 2008, 6:17am
I am traying to design a digital varactor, is it possible to to have a minimum capacitance of 11fF  by putting in serie 3 mim cap  without layout issues  ?
Thanks.
Tareeq
vivkr
Re: Minimum cap
Reply #1 - Dec 30th, 2008, 1:07am
Hi Tareeq,
I would only be worried about how you set the DC levels of the intermediate nodes
in this series connection. There may also be antenna error issues for the same reason as any charge deposited on the intermediate nodes has no path through which it can flow out.
Moreover, 11 fF is a very small cap value. You would be very sensitive to interconnect
parasitic, although the bottom-plate parasitic of MIM may not be an issue.
Vivek
barry
CA
Re: Minimum cap
Reply #2 - Dec 31st, 2008, 2:07pm
Hi Tareeq,
A standard approach for a differential oscillator is to have two varactors connected in series between the two terminals of the differential inductor. The top plates face the inductor. The bottom caps are the control voltage.
You should not need three capacitors in series to achieve 11fF. In fact, Staezewski et. al. used a 38aF unit capacitor in their DCO published in JSSC Dec. 2004. The PDK varactors are typically much larger, but you can layout a smaller one.
