Apr 26th, 2024, 10:12am
PCB trace model (Read 7370 times)
jeffyan
PCB trace model
Dec 10th, 2008, 12:07am
hi all,
how can i do PCB trance modelling, can you provide some good information? thanks
jeff Smiley
SRF Tech
Arizona
Re: PCB trace model
Reply #1 - Dec 10th, 2008, 11:51am
Hi Jeff,
There are a whole slew of tools out there than can help you. A lot depends on what level of accuracy you need.  If you are dealing with an very precision, narrow or broadband RF signal, you may need to get a 3-D field solver.  Ansoft, is one example of many big names that have a variety of tools that can help out. (google spicelink or HFSS for an introduction)
If your design is lower frequency and Transmission line accuracy is not as critical (only you can decide this), you could probably get away with a simple strip-line/micro-strip calculator and so forth.  here is a simple example website:  http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=util_pcb_imp_calculato...
though there are many others.
A lot depends on the accuracy you need and how much time and money you are able to invest.
www.srftechnologies.com
Frank Wiedmann
Munich, Germany
Re: PCB trace model
Reply #2 - Dec 11th, 2008, 12:50am
If you would like to use a field solver, you could take a look at the free Sonnet Lite, see http://www.sonnetsoftware.com/products/lite/index.asp.
jeffyan
Re: PCB trace model
Reply #3 - Dec 11th, 2008, 4:41am
thank you so much!!
kanan
Re: PCB trace model
Reply #4 - Jul 10th, 2009, 8:08pm
For not so accurate applications you could try using lmg in the cadence environment to visualize the pcb cross-section and export it to mtline.
raja.cedt
Re: PCB trace model
Reply #5 - Jul 10th, 2009, 9:08pm
hi
  why don't you use transmission line model?
