rajdeep
Thats great!
Just one point here. My suggestion of using var = I(pwrp,pwrp_PMC) can be looked as a current controlled variable! So, instead of var, if you use an electrical branch, say I(p,n) then it becomes your CCCS! But, whatever way you right, the most imp thing was to short pwrp, pwrp_PMC before probing the current thru that branch :), which you have done now!
Rajdeep
