Sep 28th, 2026, 11:15am
Model for Average current consumption in Verilog (Read 7646 times)
Sinner
Dec 10th, 2008, 4:54am
I am relatively new to verilog
Anyone has a model for current measurement for PMC. For both peak currents and average currents.
jbdavid
Re: Model for Average current consumption in Verilog
Reply #1 - Dec 18th, 2008, 11:44am
This has been here a while with no answers..
in Verilog-A we usually measure current with an
Imeas = I(node1,node2);
statement.. but "PMC" to me should be followed with "Sierra" - probably not what you meant..  care to expound?
jbdavid
Sinner
Reply #2 - Dec 18th, 2008, 8:30pm
Thanks..
In this case it stands for Power management controller
Smiley
I am using this construct, to elaborate
I have to measure the current flowing from the supply to my PMC with the supply itself ramping up or down.
Using
I(n1,n2) <+ V(n1,n2)*1/r  where r is a very low value resistance to minimize the drop
gives me extremely high current values
Is their another way to do this measurement?
rajdeep
UK
Reply #3 - Dec 19th, 2008, 3:32am
Are  you adding the small r to measure the current?
If that is the case you do not need that perhaps!
Just use,  var = I(pwrp,pwrp_PMC) to probe
the current thru  pwrp, pwrp_PMC branch.
Make sure that these two nodes are shorted to each other
in your design. I assumed pwrp = the node that corrsponds
to the power supply and pwrp_PMC = node that is connected
to the power supply pwrp. var is a real variable.
This should  help.
Rajdeep
Sinner
Reply #4 - Dec 23rd, 2008, 3:38am
Thanks Rajdeep,
I found another way to do it.
I have shorted my PAD and PMC Supply and in parallel I am using a CCCS with gain of 1, so whatever current flows in the branch also flows from the dependent source.
rajdeep
UK
Reply #5 - Dec 24th, 2008, 3:07am
Thats great!
Just one point here. My suggestion of using var = I(pwrp,pwrp_PMC)
can be looked as a current controlled variable! So, instead of var,
if you use an electrical branch, say I(p,n) then it becomes your CCCS!
But, whatever way you right, the most imp thing was to short pwrp, pwrp_PMC before probing the current thru that branch  :), which
you have done now!
Rajdeep
