Aug 17th, 2024, 2:22pm
Pages: 1 2
CMFB sensing circuit (Read 9167 times)
adesign
Dec 10th, 2008, 10:02pm
I've come across an opamp for an integrator of a sigma-delta ADC. The figure given
in this mail shows the CMFB sensing circuit for this opamp.
In the attached figure, OUTP and OUTM are the differntial output nodes of the
opamp. phi1 is the integrating phase and phi2 is the sampling phase. phi1 and
phi2 are two non-overlapping clocks operating at around oversampling ratio of
128. CMFB is the output common-mode voltage sensed by this circuit.
My queries are:
1) How is this CMFB sensing circuit working?
2) For doing ac analysis of the opamp, what load should be connected at the
opamp outputs? There is no tranac(ac simulation at some transient point) option
in my simulator.
Please comment.
ADesign
ricky
Re: CMFB sensing circuit
Reply #1 - Dec 25th, 2008, 5:56pm
Hi,ADesign
   i face the same question as you when using a sc CMFB for an integrator of a sdadc...do you get a solution?
Reply #2 - Dec 25th, 2008, 6:29pm
You need to show the sequence of the clock signals for this to be meaningful. It looks like you are doing capacitive voltage averaging, but  without the clocking sequence it is tough to say.
adesign
Reply #3 - Dec 28th, 2008, 11:57pm
The clocking sequence is attached herewith.
HdrChopper
Reply #4 - Dec 29th, 2008, 4:08am
Hi ADesign,
The circuit you are using is averaging the differential outputs of your amplifier, so that such voltage is afterwards amplified and fed back by means of your CMFB circuit.
Just think of each switched capacitor as if it was a resistor: in average it behaves as such. When you replace it by a resistor you are left with a resistive network and the capacitors connected in parallel provide a zero for compensating some other pole in the CMFB loop.
Hope this helps
Tosei
Keep it simple
aaron_do
Reply #5 - Dec 29th, 2008, 7:29am
I'm not sure exactly how it works...are you sure you drew it correctly? I'm not too sure about switched cap circuits anyway, so maybe its right...
Anyway i just wanted to add that its probably feeding back the average of 2VC - (OUTP+OUTM) ... i.e. the error signal...I'd be interested in how VC comes into the picture though.
cheers,
Aaron
adesign
Reply #6 - Dec 29th, 2008, 8:16pm
Hello Aaron,
Thanks for your reply. VC is the desired output common mode voltage generated from some reference bias.
-ADesign
adesign
Reply #7 - Dec 29th, 2008, 8:20pm
Thanks Tosei.
What is the purpose of R here? Is it current limiting resistor when the output swing is maximum?
This condition may arise when the output swing is maximum.
aaron_do
Reply #8 - Dec 30th, 2008, 1:14am
I understand that VC is the desired common-mode voltage, but i'm a bit puzzled how it actually fits in. When you write VC above the wire, is that supposed to be a voltage source , VC, accross the cap?
Also a bit unsure why you need R when the switched cap is supposed to emulate a resistor...
cheers,
Aaron
adesign
Reply #9 - Dec 30th, 2008, 1:27am
Yes, VC is the voltage source.
I think R is to limit the current when OUTP and OUTM are at +/-maxima. Please correct me, if I'm wrong.
ADesign
HdrChopper
Reply #10 - Dec 30th, 2008, 2:42pm
Hi ADesign,
I think the series R could be there to just provide a pole in your CMFB loop. Such pole might be there for stability reasons and/or for providing antialiasing means for your CMFB circuit. I do not think the second option makes too much sense though, since usually noise aliasing in a CMFB circuit is not relevant.
Tosei
Keep it simple
XY-oriented
Reply #11 - Jan 5th, 2009, 2:08am
hi guys...
I don´t thing the schematic is correct because VC don't play any role … but if  the left PH2 switches are connect to GND instead of VC such that C1 is charged with a voltage of -VC then when PH1 is  active  averaging occur in each half branch (assuming C1=C2)
((VOUTP-VCMFB)-VC)/2 + ((VOUTM-VCMFB)-VC)/2
and VCMFB=(VOUTP+VOUTM)/2 -VC as expected
is my analysis right ? What do you think ?
« Last Edit: Jan 5th, 2009, 6:14am by XY-oriented »
aaron_do
Reply #12 - Jan 5th, 2009, 3:21am
that's what i was thinking too...
HdrChopper
Reply #13 - Jan 6th, 2009, 6:39pm
Hi XY-oriented,
I think your analysis is correct, except that instead of GND you should connect the left PHI2 swtich to the desired voltage to  bias any current source inside the opamp topology.
Such voltage difference (current source bias - VC) is the one performing the comparison in the SC CMFB circuit.
Ultimately what the circui shhould give at CMFB node is
VCMFB=(VOUTP+VOUTM)/2 -(VC-current source bias)
I think the posted circuit just shows the sensing part of the CMFB but it is not complete since the comparsion is missing.
Tosei
Keep it simple
XY-oriented
Reply #14 - Jan 6th, 2009, 11:46pm
Thanks Tosei,
you are right ... I forgot the bias  ;)
Redouane
Pages: 1 2
