aaron_do
In a limiting amplifier + RSSI, the limiting amplifier has a certain output swing, for example 1 V pk-pk. After each limiting stage, there is a peak detector. So my question is, does the peak detector need to have a "linear" output up to an input voltage of 1 V pk-pk. I put linear in "" because i know we're actually looking at the DC output versus AC input. My thinking is that the RSSI detection range will be low if the peak detectors don't work up to the full output swing of the limiting amplifiers.
Part 2... Its difficult to get a "linear" peak detector up to 1 Vpk-pk input, so what are the implications of have a lower limiting output, 0.5 V pk-pk for example...
thanks, Aaron
