Sep 17th, 2024, 5:00pm
pnoise of an oscillator (Read 2102 times)
yomnat
New Delhi
Dec 17th, 2008, 9:33pm
I'm trying to find the phase noise of a current-controlled oscillator using spectre. The controlling current comes from a bandgap-reference, but the reference current itself is modulating at a lower frequency (due to chopping).
What is the setup/spectre pss@pnoise setting required do this kind of analysis?
Freq(cco) = 1.6GHz
Freq(chopping) = 4MHz
Re: pnoise of an oscillator
Reply #1 - Dec 17th, 2008, 11:20pm
Yomnat,
  It sounds like you want to simulate a VCO, an autonomous circuit,
with a driven source, the chopping source. As mentioned in a recent
append Spectre RF will support this analysis from MMSIM71.
from the thread, http://www.designers-guide.org/Forum/YaBB.pl?num=1227668750
Spectre will support the autonomous QPSS ( and corresponding small
signal analyses, like PAC, PXF, PNOISE, etc ) in MMSIM7.1. You can
specify a guess frequency for the LO in the GUI, it is very much like
what you do for the autonomous PSS simulation.
