vivkr
Hi Tareeq,
I would only be worried about how you set the DC levels of the intermediate nodes in this series connection. There may also be antenna error issues for the same reason as any charge deposited on the intermediate nodes has no path through which it can flow out.
Moreover, 11 fF is a very small cap value. You would be very sensitive to interconnect parasitic, although the bottom-plate parasitic of MIM may not be an issue.
Vivek
