Apr 28th, 2024, 3:46pm
Driver impedance, slew rate, loading and signal integrity (Read 645 times)
neoflash
Mixed-Signal
Designer
Dec 22nd, 2008, 6:17am
Assume we are designing a CMOS DDR3 driver, user requested different output driver impedance to cover different capacitive loading.
For example, 18 DRAM units may require 20ohm output impedance while 36 units may require 12ohm output impedance.
I'm curious that if whether we should use a faster slew rate for heavy capacitive loading, or use a slower slew rate?
Fast edge rate will incur more reflection, any consideration on this effect? Please recommend some literature if any, thanks.
SRF Tech
Arizona
Re: Driver impedance, slew rate, loading and signal integrity
Reply #1 - Jan 2nd, 2009, 8:45pm
Hi Neo,
 I would first say that what you are looking for is to ideally have a precise slew rate to meet your timing requirements, that is constant for either large or small capacitive loads.
I would not try to adjust slew rates, but rather drive currents so that slew rates are consistent over all operating conditions (and that they meet your timing specifications for the DDR3 standard).  That should be your goal.
Let me know if I misunderstand what you are asking
Stephen
www.srftechnologies.com
shashi.kiran
india
Reply #2 - Jul 9th, 2009, 4:26am
I completely agree with stephen , since DDR3 driver working around 800mhz it would not be suggestive to slew it and not meet the DDR3 timing spec. However , if ur worrying abu signal integrity its always suggestive to skew the driver and to have better calibration for termination..etc.
