trond
I have a behavioral model of a fractional N PLL (PFD,CP,LP,VCP, Divider, Sigma Delta Modulator). I use the model to obtain the periods at the output of the PLL which I use to calculate the phase noise.* All models used are ideal and have no additional noise sources.
My question is regarding the phase noise plot at the o/p of the PLL. As well known each block will have a noise transfer function to the o/p which is shown in the figure. Since only the SDM contributes qunatization noise which modulates the PLL o/p frequency I would expect the phase noise plot obtained by the Matlab script to be that of the modulator noise only, as everything else is ideal.
However, the phase noise plot resembles more that of the total noise plot shown in the figure. I don't understand why I do not obtain a plot showing the quantization noise of the SDM only, which is shaped by the NTF of the SDM and the PLL loop filter.
The only reason I can think of is because the model is a closed loop model and the individual plots shown in the figure are essentially from an open loop.
Can anyone help me understand this trivial question?
* See paper "Predicting the Phase Noise and Jitter of PLL-Based Frequency Synthesizers" on this website, page 45.
