If using Cadence simulators, then yes, you'll need to install IUS (LDV is the old name for the stream, but there are no supported LDV versions these days).
The IC6 family does not contain any simulation at all (in earlier IC versions, such as IC5141, you had spectre, but that has been separated into a separate MMSIM stream, such as MMSIM70).
So, if you want to do circuit simulation or RF simulation, you'd need MMSIM70, and if doing mixed-signal simulation, you'd use IUS82 (for example) - MMSIM70 and IUS82 are the latest versions.
