Nothing obvious I can see. I was going to try simulating with your netlist, but the PDF seems to be a bitmap rather than containing the text, so I can't select the text and paste into a file (I would have just invented some transistor models).
There were some problems a while back (around August/Sept last year) with inherited connections netlisting in the AMS OSS netlister, but the netlist looks as if it's probably OK to me, so I don' think you're suffering from those.
If you can upload the actual file (as a tar or tgz file), I'll take a look.
