Jul 16th, 2024, 10:19am
What is actually "beat frequency" (Read 1541 times)
DoYouLinux
Jan 15th, 2009, 8:14am
Well, it may seem strange asking this question, perhaps you all know about this. However, it seems strange to me.  :o
What is a beat frequency, as we can see from PSS SpectreRF sim ?
When I have 1 GHz and 900 MHz, it is equal to 100 MHz,
but when I have 1 GHz and 920 MHz, it is equal to 40 MHz ???
It is not equal to the difference between the two frequencies in all cases  :-/
Thank you so much again,
DYL
Frank Wiedmann
Munich, Germany
Re: What is actually "beat frequency"
Reply #1 - Jan 15th, 2009, 8:28am
See http://www.designers-guide.org/Forum/YaBB.pl?num=1224609785/5#5. 40 MHz divides both 1 GHz and 920 MHz, 80 MHz does not.
ACWWong
Oxford, UK
Reply #2 - Jan 15th, 2009, 10:18am
yes its the "highest common divisor" frequency for the large tone frequencies in your setup (including divided down frequencies).
DoYouLinux
Reply #3 - Jan 16th, 2009, 12:02am
Oh, thanks a lot, guys Cheesy
This helps me to be more clear on this
DYL
Reply #4 - Jan 17th, 2009, 6:29am
Your post is usage of specific EDA vendor's simulator. There is no Design issue.
Please post to "The Designer's Guide Community Forum ≫ Simulators ≫ RF Simulators".
DoYouLinux wrote on Jan 15th, 2009, 8:14am:
There is no "beat" in analysis statement. Also see "spectre -h pss".
You should not use term "beat" in PSS setting. Expression of "beat" is not proper.
Fundamental frequency of PSS is not beat frequency.
I can't understand why Cadence has kept to use this expression of "beat" in PSS's setting UI.
