May 3rd, 2024, 10:03am
Vgd in breakdown in PSS analysis of VCO (Read 689 times)
gorkhim
San Jose
Jan 22nd, 2009, 11:20pm
I am trying to design a VCO with a nanowire transistor (Operating Freq = 100G). Breakdown voltage for the transistor is 1.5V. I used 1V VDD and got 1Vp-p swing for transient analysis. When I started PSS, it gives warning for "Vgd in breakdown." I designed to have 600mVp-p swing and still get the same warning. Does anyone suggest me why I am getting such warnings in PSS not in transient?
vivkr
Re: Vgd in breakdown in PSS analysis of VCO
Reply #1 - Jan 22nd, 2009, 11:38pm
Have you tried to plot the transient waveforms from the PSS analysis? I would look at those, including the initial transient results which are not saved by default (you need to enable that option in the PSS form).
I sometimes had the problem that spectre issued a warning about some oxide breaking down etc, but the voltages were never large enough for that. I did not see this in PSS but in plain transient sometimes.
Best regards,
Vivek
Reply #2 - Jan 23rd, 2009, 3:27am
gorkhim wrote on Jan 22nd, 2009, 11:20pm:
If such warnings are reported only during shooting newton iterations, generally you can ignore these warnings.
But if you see such warnings even in steady state, there exists a real problem.
http://www.designers-guide.org/Forum/YaBB.pl?num=1228240587/5#5
