Hello All,
I am trying to analyze phase noise for a design involving cross-
coupled LC oscillator. I am able to get the PSS working, however, the
pnoise analysis throws up a strange warning. I have attached the
simulator log file below.
I tried implementing the suggestion posted at
http://www.cadence.com/Community/blogs/rf/archive/2008/08/26/guidelines-for-simu...but it didnt seem to make any difference in the results.
Has anyone faced this kind of issue while simulating their oscillator
design? Any inputs is highly appreciated.
VP
________________________________________________________________________________
_____________
SIMULATOR log file :
Periodic Steady-State Analysis `pss': guessed fund = 106.2 GHz
Warning from spectre during IC analysis, during periodic steady state
analysis `pss'.
WARNING (SPECTRE-16255): Initial condition of 0 V between nodes
OUTp and 0 converted into initial guess (nodeset) because there is no
capacitive path to ground.
`pss': time = (0 s -> 2.04708 ns)
Important parameter values in tstab integration:
start = 0 s
outputstart = 0 s
stop = 2.04708 ns
period = 9.4162 ps
step = 2.00942 ps
maxstep = 376.648 fs
ic = all
skipdc = no
reltol = 1e-06
abstol(I) = 1 pA
abstol(V) = 1 uV
temp = 27 C
tnom = 27 C
tempeffects = all
method = gear2only
lteratio = 3.5
relref = sigglobal
cmin = 0 F
gmin = 1 pS
pss: time = 51.22 ps (2.5 %), step = 376.6 fs (18.4 m%)
pss: time = 153.7 ps (7.51 %), step = 376.6 fs (18.4 m%)
pss: time = 256.1 ps (12.5 %), step = 376.6 fs (18.4 m%)
pss: time = 358.6 ps (17.5 %), step = 376.6 fs (18.4 m%)
pss: time = 460.6 ps (22.5 %), step = 376.6 fs (18.4 m%)
pss: time = 563.1 ps (27.5 %), step = 376.6 fs (18.4 m%)
pss: time = 665.5 ps (32.5 %), step = 376.6 fs (18.4 m%)
pss: time = 767.7 ps (37.5 %), step = 9.276 fs (453 u%)
pss: time = 870 ps (42.5 %), step = 29.51 fs (1.44 m%)
pss: time = 972.4 ps (47.5 %), step = 46.02 fs (2.25 m%)
pss: time = 1.075 ns (52.5 %), step = 36.8 fs (1.8 m%)
pss: time = 1.177 ns (57.5 %), step = 29.57 fs (1.44 m%)
pss: time = 1.279 ns (62.5 %), step = 30.46 fs (1.49 m%)
pss: time = 1.382 ns (67.5 %), step = 24.38 fs (1.19 m%)
pss: time = 1.484 ns (72.5 %), step = 34.03 fs (1.66 m%)
pss: time = 1.586 ns (77.5 %), step = 29.02 fs (1.42 m%)
pss: time = 1.689 ns (82.5 %), step = 32.04 fs (1.57 m%)
pss: time = 1.791 ns (87.5 %), step = 21.18 fs (1.03 m%)
pss: time = 1.894 ns (92.5 %), step = 31.87 fs (1.56 m%)
pss: time = 1.996 ns (97.5 %), step = 28.98 fs (1.42 m%)
The Estimated oscillating frequency from Tstab Tran is = 106.176 GHz
(Hz).
`pss': time = (2.04708 ns -> 2.0565 ns)
Important parameter values in pss iteration:
start = 2.04708 ns
outputstart = 0 s
stop = 2.0565 ns
period = 9.41835 ps
steadyratio = 10e-03
step = 2.00942 ps
maxstep = 94.1835 fs
ic = all
skipdc = no
reltol = 1e-06
abstol(I) = 1 pA
abstol(V) = 1 uV
temp = 27 C
tnom = 27 C
tempeffects = all
errpreset = liberal
method = gear2only
lteratio = 3.5
relref = sigglobal
cmin = 0 F
gmin = 1 pS
pss: time = 2.047 ns (2.63 %), step = 27.66 fs (294 m%)
pss: time = 2.048 ns (7.55 %), step = 27.02 fs (287 m%)
pss: time = 2.048 ns (12.7 %), step = 27.51 fs (292 m%)
pss: time = 2.049 ns (17.6 %), step = 29.57 fs (314 m%)
pss: time = 2.049 ns (22.7 %), step = 31.31 fs (332 m%)
pss: time = 2.05 ns (27.7 %), step = 35.86 fs (381 m%)
pss: time = 2.05 ns (32.5 %), step = 18.33 fs (195 m%)
pss: time = 2.051 ns (37.5 %), step = 10.9 fs (116 m%)
pss: time = 2.051 ns (42.5 %), step = 9.163 fs (97.3 m%)
pss: time = 2.052 ns (47.8 %), step = 31.33 fs (333 m%)
pss: time = 2.052 ns (52.6 %), step = 29.66 fs (315 m%)
pss: time = 2.053 ns (57.6 %), step = 28.94 fs (307 m%)
pss: time = 2.053 ns (62.5 %), step = 29.41 fs (312 m%)
pss: time = 2.053 ns (67.8 %), step = 31.73 fs (337 m%)
pss: time = 2.054 ns (72.5 %), step = 33.36 fs (354 m%)
pss: time = 2.054 ns (77.9 %), step = 38.53 fs (409 m%)
pss: time = 2.055 ns (82.6 %), step = 17.55 fs (186 m%)
pss: time = 2.055 ns (87.5 %), step = 9.45 fs (100 m%)
pss: time = 2.056 ns (92.6 %), step = 9.585 fs (102 m%)
pss: time = 2.056 ns (97.5 %), step = 31.47 fs (334 m%)
Pinning node: 46, harm: 1, name: U1.M3.Mpx:int_b, value: (0.242847,
0.343320)
Harmonic balance
Important harmonic balance parameters:
RelTol=1.00e-06
abstol(I)=1.00e-12 A
abstol(V)=1.00e-06 V
ResidualTol=1.00e+00
LTE_Ratio=3.50e+00
Steady_Ratio=1.00e+00
MaxNewtonIter=50
********** initial residual **********
Resd Norm=2.18e+05 at node U1.M4.Mpx:int_b harm=(10)
********** iter = 1 **
