Aug 15th, 2024, 4:40am
PSS: Difference between writepss/readpss and writefinal/readic (Read 3310 times)
Niklas
Aachen, Germany
Feb 02nd, 2009, 9:29am
When using PSS analysis one can set the writepss/readpss and writefinal/readic options respectively, to save the steady state conditions and use them as an initial condition for the next simulation. From the Spectre documentation I don't really get what the difference between both methods is. Is one method superior to the other or is there any rule under which simulation conditions one should use one method or the other?
Best regards
Niklas
Re: PSS: Difference between writepss/readpss and writefinal/readic
Reply #1 - Feb 3rd, 2009, 10:09pm
writepss/readpss captures the final steady-state solution, both for shooting and (since recent MMSIM701 ISRs and MMSIM71), harmonic balance. This represents the entire solution - the whole period. Using writefinal/readic only captures the final DC operating point (and reuses it).
Using writefinal/readic means that it still needs to solve from scratch; it's just that the DC for the steady-state may be closer to the final settled value. With writepss/readpss it should be very close to the final solution (it still needs to solve, because the circuit conditions may have changed a little in the meantime, between the run with writepss and the run with readpss).
Does that help?
Niklas
Aachen, Germany
Reply #2 - Feb 3rd, 2009, 11:49pm
OK, now I got it. Thank you for your help!
Unfortunately, with respect to simulator options the Cadence documentation is often very indefinite Sad
Niklas
