Aug 17th, 2024, 10:17am
Question on current mirror implementation (Read 3051 times)
kidman
Jan 31st, 2009, 3:52pm
A current mirror that consists of only 2 transistors won't copy the exact reference current due to channel length modulation. The solution to that is cascoding as well know to shield the mirror from VDS variation and copy the exact reference current.
My question is, is the normal current mirror that's not cascoded used in any practical design? I'm asking this because I'm wondering how does a designer get his circuit working after the PVT variations and so on using the basic current mirror that even without PVT variations will not copy the current accurately.
Re: Question on current mirror implementation
Reply #1 - Feb 1st, 2009, 12:28pm
They are used all the time. Many applications for a current source do not require either good absolute value, or good PVT stability. Example - the current source under a differential pair can usually function properly with a lot of variance (2X over PVT without problems)
If you are looking for tight tolerance on any circuit, it is going to require adjustment circuits or the architecture needs to be reviewed to get rid of tolerance needs.
Reply #2 - Feb 1st, 2009, 7:51pm
Kidman,
The simple current mirror are often used. That depends on the performance requrements.
Yawei
raja.cedt
Reply #3 - Feb 2nd, 2009, 3:07am
hi kidman,
                 Based on the application type mirror being used is decided,for example in differential amplifiers if the i/p variations are not much then simple mirror is the first choise,but if u want really high CMRR then u have to go for cascode.again cascode consume a lot of headroom for voltege,in that case high swing mirror is the best choice.This information u can get from razaavi.
Thank you.
kidman
Reply #4 - Feb 5th, 2009, 5:08am
thanks for your i/p guys
