Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 10
th
, 2024, 12:43pm
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› Cross couple LC VCO
Previous topic
Next topic
Cross couple LC VCO (Read 12448 times)
Mehran
Cross couple LC VCO
Feb 03
rd
, 2009, 5:20am
Hi All,
I am trying to design a cross couple LC vco. The Q of my tank is about 5. I have sized my transistor to have gm~1.5/Rtank. I have read in the text books that we should use 2-3 times instead of 1.5. It does oscillate in the simulation.
Can any body tell me how is the normal way people in industry make sure that their VCO will oscillate?
If I run the corner and it oscillates in all the corners, Is it the safe method?
Thanks in advance.
Mehran
IP Logged
Re: Cross couple LC VCO
Reply #1 -
Feb 6
th
, 2009, 7:32pm
Mehran wrote
on Feb 3
rd
, 2009, 5:20am:
How to confirm stable and rigid oscillation in your simulation ?
Large Signal Steady State Analysis such as Autonomous Shooting Newton or Autonomous Harmonic Balance ?
Small Signal Analysis for evaluation oscillation margin by using Loop Gain or Negative Impedance ?
Kita━━━━━━(゚∀゚)━━━━━━ !!!!!
http://www7.plala.or.jp/ungeromeppa/flash/kita.html
http://www.youtube.com/watch?v=mjIxGh55bMM&feature=related
IP Logged
Mehran
Reply #2 -
Feb 7
th
, 2009, 12:43am
Hi panchoo,
Thanks for replying.
the way I have in my mind is, running the transient analysis with small pulse of current (to kick-start)and I can see the oscillation build up and the steady amplitude, then I will run the PSS shooting and I will check if there is a steady state solution there also and I will check the amplitude with transient.
can you tell me how you experienced designer make sure that it will oscillate? I didn't get your questions. Are those questions the way I should go or you mean something else.
how do you measure the loop gain of your oscillator?
Mehran
IP Logged
Reply #3 -
Feb 7
th
, 2009, 4:29am
Mehran wrote
on Feb 7
th
, 2009, 12:43am:
Are those questions the way I should go.
Generally you should do both.
Mehran wrote
on Feb 7
th
, 2009, 12:43am:
Same as amplifier with feedback.
But for LC oscillator, I use Negative Impedance although I can also evaluate Loop Gain.
http://www.zen118213.zen.co.uk/RFIC_Circuits_Files/LC_Oscillator.pdf
Here you can evaluate Negative Impedances at pure small signal analysis and small signal analysis subjected to master large signal analysis.
From latter, you can also evaluate loss of oscillator at steady state.
By the way, have you been able to resolve the following issues ?
http://www.designers-guide.org/Forum/YaBB.pl?num=1229048701/8#8
Last Edit: Feb 8
th
, 2009, 12:37am by pancho_hideboo
IP Logged
oermens
Reply #4 -
Feb 7
th
, 2009, 2:44pm
can you explain more about evaluating loop gain and negative impedance? which analysis do you use? sp? if i perform sp on the tank, the resistance should be approximately g
tank
|| -g
active
IP Logged
Reply #5 -
Feb 7
th
, 2009, 7:35pm
oermens wrote
on Feb 7
th
, 2009, 2:44pm:
tank
|| -g
active
You don't seem to understand measurement of interstage impedance.
But AC analysis is more suitable than SP analysis.
Port needed in SP analysis always perturbs oscillator since it has impedance.
oermens wrote
on Feb 7
th
, 2009, 2:44pm:
which analysis do you use? sp??
Small Signal AC Analysis and Small Signal AC Analysis subjected to Master Large Signal Analysis such as HB-SS and PSS/PAC.
http://www.designers-guide.org/Forum/YaBB.pl?num=1221012939
In Agilent ADS, such impedance probe(short probe) is provided as standard probe.
But you can create it using combination of vsources and isources by yourself.
In the above example, I use my own impedance probe for Cadence Spectre.
You can create differential impedance probe if you understand diff/com mode copncept correctly.
Also you can create diff/com Loop Gain Probe by yourself.
But If you are Cadence Spectre Player, STB are avaialble for evaluation Loop Gain.
http://www.designers-guide.org/Forum/YaBB.pl?num=1215501569/2#2
By the way have you been able to resolve the following issues ?
http://www.designers-guide.org/Forum/YaBB.pl?num=1228240587/26#26
http://www.designers-guide.org/Forum/YaBB.pl?num=1231617402
Last Edit: Feb 8
th
IP Logged
emad
Cairo, Egypt
Reply #6 -
Feb 8
th
, 2009, 5:47am
Mehran
Obviously the 2-3 rule is meant as a guideline rather than a rigid number. It stems from the fact that gain compresses as oscillation grows as well as a PVT margin. It depends on the allowed signal swing. A larger swing requires higher loop gain to fully switch the pair. However, higher loop gain degrades flicker noise ( Can't capture that in equations yet but perhaps I'll do that one day).
In a nutshell, if your worst case, PVT, RLC-extracted, design has a gain of 1.5 then it's probably ok. If this is your typical, schematic level, 27C design then 1.5 won't do in the real world.
In my experience, 1.5 is a bit too small, 1.8-2.0 would give me better sleep in the nights between tapeout and measurement.
Emad
IP Logged
oermens
Reply #7 -
Feb 8
th
, 2009, 9:38am
thanks for the reply, your insight is always appreciated.
pancho_hideboo wrote
on Feb 7
th
, 2009, 7:35pm:
Yes we switched to MMSIM stream, but I didn't do much related to the ocean scripting.
on Feb 7
th
, 2009, 7:35pm:
Yes.
IP Logged
Mehran
Reply #8 -
Feb 9
th
, 2009, 3:53am
Hi Panchoo,
Thanks for your help.
I still have a problem with the spectrum on previous issue.
IP Logged
Mehran
Reply #9 -
Feb 9
th
, 2009, 4:43am
Hi Emad,
May I know how do you measure the loop gain? Do you measure the loop gain of your oscillator as Panchoo said,in spectre, putting a differential probe between the output of the VCO and the gates? or you first characterize your tank resistance and then use the DC operating point gm to calculate gm*Rtank?
The problem is, if you look at the attached file and results, loop gain in stability analysis is around 1.7 while if I use gm*Rtank=15.8m*130=2.054.
Can you tell me how do you do it?
(PS: I have learn a lot from your papers)
[img][/img]
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
