Aug 17th, 2024, 4:12am
Skin effect on DC transient? (Read 7046 times)
7-7
Feb 07th, 2009, 2:14am
Hello everyone.
I would be grateful if anyone could answer my following query.
Skin effect limits a conductor's cross-sectional area through which an AC current can flow. This has an effect on the resistance of that conductor to the AC current.
Is a DC transient also restricted to flow into a partial region of the cross-sectional area of a conductor, or does a DC transient, no matter how steep, flow through all the area of a conductor, like a steady DC current?
Many thanks.
Re: Skin effect on DC transient?
Reply #1 - Feb 7th, 2009, 4:03am
7-7 wrote on Feb 7th, 2009, 2:14am:
or does a DC transient, no matter how steep, flow through all the area of a conductor, like a steady DC current ?
I can't underestand what you mean by "DC transient".
Also I can't understand what you mean by "like a steady DC current".
"Skin effect" is a real physical phenomena.
If frequency components of current are high, "Skin effect" is appeared for these frequency components.
But low frequency components don't undergo "Skin effect" as far as a conductor is linear.
7-7
Reply #2 - Feb 7th, 2009, 7:24am
Pancho_hideboo thank you for replying.
By DC transient I mean a steep increase in current flow, say from 2 A to 1000 A in say 10^-3 sec, but with the current flowing always in the same direction.
By steady DC current I mean that the rate of change of current is zero i.e. there is no current change with respect to time.
I am aware of the skin effect for a current whose direction of flow changes alternatively i.e. an AC current. I would like to know if a similar effect applies to a DC transient, which was described above.
Thank you.
Reply #3 - Feb 7th, 2009, 8:56am
7-7 wrote on Feb 7th, 2009, 7:24am:
Response is similar to LPF output driven by step input signal, since frequency characteristics of resistor is proportional to sqrt(freq).
7-7
Reply #4 - Feb 8th, 2009, 1:43am
I take your answer to mean that yes, skin effect conditions apply to a DC transient. I take it also to mean that I would have to do the harmonic analysis of the step slope. Could you please confirm if this is correct.
In that case, how do I do the harmonic analysis of the step of my previous example, from 2 A to 1000 A in 10^-3 sec ? Could you give me the full procedure and result?
Many thanks for your help.
Reply #5 - Feb 8th, 2009, 1:56am
7-7 wrote on Feb 8th, 2009, 1:43am:
What do you mean by "harmonic analysis" ?
In that case, how do I do the harmonic analysis of the step of my previous example, from 2 A to 1000 A in 10^-3 sec ? Could you give me the full procedure and result ?
Generally use Transient Analysis. But about details of procedure, it depends on what simulator engine you have.
For example, if you approximate step signal as periodical pulse signal with long period, you can use Harmonic Balance Analysis with pure frequency domain description of skin effect for model of line.
See TLINP (2-Terminal Physical Transmission Line) of chap-7 in the following.
http://cp.literature.agilent.com/litweb/pdf/ads2005a/pdf/ccdist.pdf
http://www.designers-guide.org/Forum/YaBB.pl?num=1227194040
If you use Agilent ADS, you can use various line models such as "TLINP" in Transient Analysis.
If you use Synopsys HSPICE, you can use "W-Element" in Transient Analysis.
If you use Cadence Spectre, you can use "mtline" in Transient Analysis.
Also you can make original line model with skin effect.
http://www.designers-guide.org/Modeling/ind.pdf
http://www.designers-guide.org/Modeling/suite.pdf
7-7
Reply #6 - Feb 8th, 2009, 4:38am
I'll rephrase it:
Am I correct in saying that I should find the constituent sine waves of the transient ramp by Fourier transform, then calculate the skin effect on each sine wave, sum the sine waves together again, and the net result, as you say, is a low pass filter on the original ramp?
If I am not correct please stop me here.
Reply #7 - Feb 8th, 2009, 5:39am
7-7 wrote on Feb 8th, 2009, 4:38am:
Conceptually correct.
But you can do this task by using AC Analysis or Harmonic Balance Analysis.
What was your question after all ?
If you want to know response of current flow output for line having skin effect, just do Transient Analysis by using line model having skin effect and step signal drive.
I can't understand what you are confusing so much.
http://sigcon.com/Pubs/edn/MixSkinandDielectric.htm
« Last Edit: Feb 8th, 2009, 6:52am by pancho_hideboo »
7-7
Reply #8 - Feb 8th, 2009, 6:24am
[quote author=pancho_hideboo link=1234001690/0#7 date=1234100396]7-7 wrote on Feb 8th, 2009, 4:38am:
You just answered it!
Thanks.
Reply #9 - Feb 8th, 2009, 7:16am
7-7 wrote on Feb 8th, 2009, 6:24am:
After all your question was how to calculate a response of linear system having transfer function H(freq) when it is driven by step signal. Very easy issue.
http://www.designers-guide.org/Forum/YaBB.pl?num=1234001690/0#0
From first your explanation, I couldn't understand what was your question at all.
