Aug 15th, 2024, 3:41am
[q] RFIC package modeler (Read 3126 times)
kidhyun
Feb 13th, 2009, 7:15am
Dear All,
 I am trying to run RFIC package modeler, but 32520 is EOLed, so I couldn't run.
 Do we have the same thing in 38520? Is the command the same (pkg) ?
Thank You
Re: [q] RFIC package modeler
Reply #1 - Feb 13th, 2009, 9:50am
pkg has been end-of-lifed for some time. It's still there in IC5141, but has had no enhancements for many years, and is only supported under legacy licenses.
It has gone in IC61.
kidhyun
Reply #2 - Feb 14th, 2009, 12:35am
Thank you for the answer.
It seems that I need to run allegro package modeler instead.
Do you know what's the command to run this?
Or do we run this in some simulation environment like icfb?
Thank You.
Reply #3 - Feb 15th, 2009, 5:18am
Yes, that's right - the Allegro package tools are what you'd use instead. There is also the "RF SIP" flow which combines the Allegro package tools with the IC environment. I'm afraid I'm not that familiar with the details, so it's best for you to contact your local Cadence office for more details.
