essam
Hello All,
I am trying to setup a QPSS simulation for a mixer. Whenever I run the simulation I get the following message:
ERROR (CMI-2446): PORT1: The frequency name F1 is inconsistent with the names listed in 'funds' for this analysis.
I know that this error appears when you have a different name in QPSS setup than what is used in the PORT placed in the schematic, or when there are extra names in QPSS setup itself.
I have checked more than once that the names in the analysis perfectly match those in schematic, and that there are no extra names/frequencies in the QPSS setup.
I also deleted the analysis and did it again, and deleted the port and placed it again.
NOTHING WORKS!
ANY SOLUTION ?!!!
Thanks, Essam
