Jul 17th, 2024, 2:20am
simulating net negative impedance of LC VCO (Read 1356 times)
oermens
Feb 24th, 2009, 2:58pm
I tried to simulate using the method described here:
http://www.designers-guide.org/Forum/YaBB.pl?num=1233667204/5#5
I'm not sure if my setup is correct. I put isource on the output node with PAC magnitude=1 and plotted the resulting voltage of PAC simulation which is Rtank at the oscillation frequency. what is the correct setup for this simulation?
