Jul 17th, 2024, 12:19am
how to design a IF input stage for superheterodyne receiver (Read 4138 times)
mydreamhouse
Feb 24th, 2009, 8:35am
who can tell me how to design a IF input stage for superheterodyne receiver
the IF frequency is about 180MHZ,and followed by external LC BPF.
as i known, the IF LC BPF must be match with IF input stage,but i don't know how to design it.(if the BPF matched resister is low, is it necessary to design a COMMOM GATE(CG) stage to match the LC BPF? or directly Gate input?(CS).
View Profile mydreamhouse   IP Logged
mydreamhouse
Re: how to design a IF input stage for superheterodyne receiver
Reply #1 - Feb 27th, 2009, 2:58am
who can give me some advice?
Reply #2 - Feb 27th, 2009, 5:48am
mydreamhouse wrote on Feb 24th, 2009, 8:35am:
mydreamhouse wrote on Feb 27th, 2009, 2:58am:
Your question is too lack of information, so no one can answer.
This is very true for all your posts too.
http://www.designers-guide.org/Forum/YaBB.pl?num=1235494642/0#0
http://www.designers-guide.org/Forum/YaBB.pl?num=1229879167/0#0
If you want someone to answer your post, you have to describe your questions regarding situation and condition in detail using industrial standard terminologies.
If your system is very narrow band system, you can use simple resonator as BPF here high impedance of next input stage is required.
Here you might be able to use impedance of next input as part of BPF.
Even though you design formal filters, there are three variations,
(1) R-R Type
(2) R-infinite Type
(3) 0-R Type
You seem to know only (1).
And for BPF design, resonator coupled structure is preferable than formal filter design.
« Last Edit: Feb 27th, 2009, 8:19pm by pancho_hideboo »
mydreamhouse
Reply #3 - Feb 27th, 2009, 9:14am
thank you, i use external LC BPF and R-R match,but ,how to design the output stage and input stage to match the LC BPF in a receiver ? (IF=200M)
Reply #4 - Feb 27th, 2009, 6:58pm
mydreamhouse wrote on Feb 27th, 2009, 9:14am:
Output Stage Impedance ----> Load Impedance of Drain Output or Impedance inserted to Source Output
Input Stage Impedance ----> Impedance terminated at Gate Input or Impedance inserted to Source Input
These options depend on requirements for Gain, Distortion, Noise characteristics and termination impedance value of filter.
mydreamhouse
Reply #5 - Feb 28th, 2009, 9:10am
thank you, in my design i use a Drain out(CS amplifier) with a 500ohm differential resister for BPF input matching, and  a CS amplifer with a 500ohm between two gates for BPF ouput matching, is this right?
