I tried to simulate using the method described here:
http://www.designers-guide.org/Forum/YaBB.pl?num=1233667204/5#5I'm not sure if my setup is correct. I put isource on the output node with PAC magnitude=1 and plotted the resulting voltage of PAC simulation which is Rtank at the oscillation frequency. what is the correct setup for this simulation?
