Hi guys,
As the title, a CML divider(DIV-1) is used to generate a group of I/Q differential signals (In, Ip, Qn, Qp) for the following mixer. Since there is another CML divider(DIV-2) following this divider(DIV-1), which means a group of differential signals will be fed into DIV-2, the I/Q loading for DIV-1 will not be balance.
Is there any suggestion or paper as reference to solve this problem?
Thanks in advance!
