The PSS analysis is analysing a single period of the PSS fundamental (25MHz).
Consequently you cannot specify time points outside of the period - since the period is 40ns, specifying a time of 51.5n or 91.5n makes no sense. In fact, what would it tell you? If you've got a steadystate solution, the noise at 51.5n and 91.5n would be the same as it is at 11.5n (remember that this is a small-signal noise analysis, not a transient noise analysis, where the noise sources are computed randomly at each timestep).
So your mistake was to specify times exceeding the periodic interval, as the simulator message stated.
