Sep 16th, 2026, 7:22pm
smoothing transition function in transient analysis (Read 1635 times)
Dracon
Mar 07th, 2009, 7:27am
Dear All,
I have a problem with function that should smooth my output signal.
The transition(V(x), td,tr,tf) add to signal rise and fall times but only in linear way.
I have written following funkction based on Lagrange interpolation between three points (x1,y1) (x2,y2) , (x12,y12) and wanted signal, after smoothing to be more exponential, but I get convergence problem:
       "internal timestep too small in transient analysis"
Note that points(x,y) are changing in time.
analog function real fsmooth;
       input x,x1,y1,x12,y12,x2,y2;
       real x,x1,y1,x12,y12,x2,y2;
     real n1,n12,n2;
           begin
                 n1 = ((x-x12)*(x-x2))/((x1-x12)*(x1-x2));
                 n12 = ((x-x1)*(x-x2))/((x12-x1)*(x12-x2));
                 n2 = ((x-x1)*(x-x12))/((x2-x1)*(x2-x12));
                 fsmooth = n1*y1 + n12*y12 + n2*y2;
     endfunction
Perhaps there is some embedded function to do this??
Thanks for your answers.
Best regards,
Dracon
Re: smoothing transition function in transient analysis
Reply #1 - Mar 8th, 2009, 8:47am
Dracon wrote on Mar 7th, 2009, 7:27am:
I have written following function based on Lagrange interpolation between three points (x1,y1) (x2,y2) , (x12,y12) and wanted signal, after smoothing to be more exponential, but I get convergence problem:
Try other interpolation filter such as spline, raised-cosine, etc.
There is no built-in function provided for such purpose.
Everyone write own interpolation filter, if needed.
Reply #2 - Mar 8th, 2009, 1:38pm
The reason why it is not built into the language is because in practice, it is very rarely needed.  My experience is that people overuse smoothing, usually at great cost in modeling and simulation time. Can I ask why you think you need it?
Dracon
Reply #3 - Mar 8th, 2009, 2:01pm
I just begun my journey with modelling circuits and thought it maybe good idea to make signal transitions as it look like in specification. I needed it for driver de-emphasis model, but now if I look on that from a perspective of large simulation time I do not think this is my goal. I think the model have to be simple for functional verifications.
